Thread: New Supra Owner
Old 03-21-2014, 08:56 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Schrom View Post
I'm at about 135k miles, would that turbo kit be to much stress on a engine with that many miles?
also, since http://www.xxrwheels.com/xxr_530.shtml do not come with 11.5's is it gonna become a pain to work with these? or even http://www.xxrwheels.com/xxr_521.shtml
Nah it's a 'yota. It'll probably be fine. Just be sure to do a compression test (or leakdown test) to ensure it's in good shape. If the oil has never been changed for 135K miles, the compression test results won't be very good. If it's been well-maintained, the compression test should show good results.
You need to pick wheels that are as wide as you need. Don't invest a penny in skinny rims that are all for show and no consideration for better traction. Your 2nd link comes in an 18x10, but I'm not sure the offset would be right. That diameter & width might work with a 305-width tire, if you can find one sticky enough. Here's one option:
http://www.tirerack.com/tires/tires....omCompare1=yes
There are lots of options in 295/35:
http://www.tirerack.com/tires/TireSe...35&diameter=18
Life begins at 30psi.
