Old 01-01-2014, 12:01 AM   #1
Moved to the MKII Supra section.
Have you pulled and tested the door switches? If the alarm were the problem the issue should have been evident right away. Nonetheless you may want to make sure the door switch wiring that runs to the alarm is properly isolated with 1N4XXX diodes.
