Old 06-01-2013, 01:18 PM   #2
pandrade
pandrade is on a distinguished road
yah besides better turbo and the things i said earlier i cant think of much else.drift motion sells new crank alt and ps pully which they save 2.6 lbs which helps a lot. i want to install a 1 piece aluminum drive shaft and i already have a super light fly wheel. not much else i can do
i would steer clear of electric water pumps, they are good enough for tracks where the car is always in motion and wont heat saturate but for a street car it will get overwhelmed very easily especialy here in florida, also when you got the belt driven pump there is peace of mind about reliability, when it lockes up or fails you will hear it but electic can fail and if your not looken at the water temp (like an instance the gf would drive the car) it could have failed and never noticed it
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
