Old 05-28-2013, 06:04 AM   #1
spainobain1234
spainobain1234's Avatar
spainobain1234 is on a distinguished road
Default Rpm Rev When Happens
Originally Posted by MA70-3.0GT View Post
Yep, if you didn't feel sick for a second, thinking you'd thrown a cambelt the first time it happened then it probably ain't fuel cut!
Just to avoid confusion for the future benefit of spainobain, the post you originally quoted said "bap bap bap noise it is NOT fuel cut ". If you refer to it as fuel cut then you'll likely get people muddled up & receive wrong advice... Not saying this to jump on anyones back or anything so don't bite my head off, just don't want you to hurt your engine at all
What rpm is your rev counter showing at the time of the problem? IIRC it'll start "bouncing" off the rev limiter actually just before the redline (at least on my JDM dash, not sure on the analogue ones though)...
At 4,000 rpm on the rev counter, the problem hits, CEL flashes, and the car bucks (hesitating and hitting a brick wall, then boosting, hitting a brick wall, then boosting again...)
Sidenote: Also the car wants to die if I tap the gas pedal in gear and let off, the rpms drop and the car dies.
spainobain1234 is offline   Reply With Quote
