Old 03-13-2013, 06:27 PM   #1
pandrade
pandrade is on a distinguished road
im not a guy that buys cars that have had motor swaps becuase you never know if it has been done right. the car could run perfect for a while then something goes bad on it then you have no idea what the problem might be since you dident do the work.i personaly would stay away from it for 2 reasons 1 becuase i did not perform the swap my self 2 beucase you can go blind into a ticking time bomb. the only time i even consider a swaped motor car is if there is EXTENSIVE paper work on it which shows a VERY well known shop has done the swap and even then im weary about buying it plus i dont know anything about the 1.5jz
some of the more seasoned guys might say otherwise but they know more about swaps then i
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
