Old 03-01-2013, 11:13 AM   #6
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
It was a very difficult decision but i took the radio out speakers,heaterboks,backseats,antenna motor and a few other stuff that you cant see.Still looks stock
Saved so 150kg.
Next i must get diff bushes made.
Great job on the weight savings.
Stiffer subframe bushings benefit more than solid diff bushes. Where did you get the info that diff bushings might help?
http://www.titanmotorsports.com/soresumofort.html
http://www.titanmotorsports.com/soresumofor9.html
You can create a budget-substitute for the front one using a stack of very wide steel washers. Not as good as the TMS replacement, but it's a decent start.
Did you ever get wider rims? You could even get the oem rims widened if you're on a budget. My first rim width upgrade was oem rear rims on the front and widened oem rear rims on the back - it worked great!!!
http://mkiv.com/techarticles/parts/o...ned/index.html
Getting the correct width of rubber, using drag-specific rubber, and the correct tire pressure will be the best first steps to getting that 1/4 mile time down.
Life begins at 30psi.
