Old 01-24-2013, 02:54 AM   #1
I'm all for converting. You should still run the car with a wideband to ensure that the fuel scaling is correct. The original MAFT unit which you are referring does actually have trim adjustments, they're just tucked away inside the unit. If you don't have a wideband in your car and don't have access to one then plan on a couple quick dyno runs and budget for that too.
