Old 01-09-2013, 03:07 AM   #17
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Codyjamesuno View Post
Ok, lets say I decide to go with the 11 inch rear wheel, what size should the front be? Would I then run something in the 300's for a rear tire?
Thanks
Cody
1) 11.5" width rims fit under the (trimmed) rear fenders just fine, and 315-width rubber is fairly common. Why would you go down to 11"?
2) Oem specs are 8" front and 9.5" rear. That's 84%. 84% of 11.5" is 9.68" (close enough to 9.5"). So 9.5" width fronts match 11.5" width rears.
Check this out:
http://mkiv.com/techarticles/parts/o...ned/index.html
...this was my first rim upgrade. I ran 9.5" oem rear rims in the front, and 11.5" widened oem rear rims in the back.
Life begins at 30psi.
