Old 10-16-2012, 11:36 AM   #2
interested!
Exclamation 1992 supra
Taking apart the suspension is pretty straight forward. I would recommend soaking the nuts and bolts over night with penetrating fluid. My friend changed out all his bushing with polys. They need to be pressed in . Also polys are stiffer but the main problem is if you replace only a few you will be mixing new and old. It will most likely cause problems that way. I would recommend doing all of them if possible.
Hi! If the set-up is the same as my 1987 supra , the arms are fitted with adjustable camber bolts . I would advise taking photos of the settings of the bolts for rebuild . also , my bolts had seized completely and this job turned out to be a complete soab but attainable with a lot of patience and time , also the tracking will need to be checked afterwards .
