Old 10-16-2012, 02:58 AM   #1
907mge
907mge's Avatar
Taking apart the suspension is pretty straight forward. I would recommend soaking the nuts and bolts over night with penetrating fluid. My friend changed out all his bushing with polys. They need to be pressed in . Also polys are stiffer but the main problem is if you replace only a few you will be mixing new and old. It will most likely cause problems that way. I would recommend doing all of them if possible.
