Old 09-20-2012, 12:30 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
I do not yet have one but do plan on buying one.
Update- I pulled the turbo system off and put the stock na header back on with the sane 4runner dist cap and msd wires. Car runs AMAZING so far it made it all the way to work and didn't skip a beat for the first time in a while!
So two things I'm goin to do. In order to run my afr gauge I am only running one o2 and jumped the wires for the second into it. I am goin to switch it to the rear bank after work to confirm I ge the same results. If I do then I will be doin the pressure check on the intercooler piping. If that checks out the I will install the turbo and check it through the intake of turbo pressuring the entire system.
My question to you is should I dis connect it at the throttle body or will it hold 50psi??
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
