Old 09-19-2012, 02:10 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Per my post above, have you checked for boost/vacuum leaks yet via pressurizing the intake yet?
One potential issue is a split vaccum (or charge air) hose that weakens with heat. A boost leak check will detect this (and an ordinary smoke test won't).
Here's another thought (while we're on the topic of split hoses):
http://autos.groups.yahoo.com/group/mkiv/message/230604
I have not yet pressurized the system I will do that this evening after building an adapter.
I pulled the code ==== 25 lean condition?? Fuel pressure is within spec.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
