Old 09-14-2012, 02:53 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Update!
I bought a new Mac tools pro fuel pressure test kit and it had a banjo bolt adapter that I hooked into the top of the fuel filter...
Results- with Vac line disconnected and plugged 51psi. Factory spec 38-44
With vac line hooked up 42psi. Factory spec 28-34
1500 rpm 55psi with vac line hooked up. That is out of factory specs so I will be replacing it.
I apologize for not adding the info about the stock distr cap. I reinstalled the original with no change. Although I did have to change plug wires back to OEM as well. So I put the 4 runner stuff back on and doubled checked that the timing is at 10btdc.
Is it possible that the added pressure from boost could damage the factory fuel regulator?? Should I stick with OEM or go to an aftermarket in your opinion.
My BOV is an HKS SSQ that I bought a recirculation nipple for so it has been blowing back into the intake post MAF, pre turbo!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
