Old 09-12-2012, 10:30 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Well after driving the car today I finally got a check engine light- Code 26= running rich. So Im leanin towards possibly a fuel regulator. Checking the fuel pressure on the GE is hell due to all the egr and related parts being above the feed line. I looked around for another port before the regulator but see nowhere else to go other then the banjo on the fuel sender but that is far from accurate.
I bypassed the turbo system and hooked up the afm directly to the intake mani with all vac lines hooked up. Fired it up, but still idled badly so I went back to find a vac line from the Bov still un capped. Oops! Then my great friend of mine without asking me unhooked my battery clearing the code so the cel went out. Not what I wanted to do. I wanted to see if the light would go out on its own.
Anyways, fired it up and it running rich right now with the cel cleared.
Afrs now at idle are 13.0-13.8 and at 1500 rpm no load afrs go to 11.8-12.5. And runs smooth no hesitation at all. But I'm sure as soon as I went down the road it would start droppin off lean again.
Any ideas greatly appreciated! The current set up jerry rig intake I made does not allow me to close the hood at all so I'm working on another setup to drive with. But those afr do not sound right to me.
I pulled the 4 runner cap off today to look at the spark trace on the cap poles, everything looked good. I am lookin in to getting a fuel pressure gauge if that checks out I will be doin a compression test aswell as leak down test. Really hoping there is a fuel problem thou!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
