Thread: Suspension
Old 07-12-2012, 09:13 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by fastsupra View Post
Is there anything else that you would recommend to get along with the coilovers and sway bars?
Have you considered wider rims and tires? Be sure to *at least* stay with the oem Z-rated rubber specs. At most, consider R-compound tires for serious roadracing, and either drag radials or slicks&skinnies for drag racing.
Also, find some correctly-sized flat washers to compress the subframe bushings. This will reduce the potentially-damaging effects of wheel hop if it occurs.
Life begins at 30psi.
