Old 06-12-2012, 04:30 AM   #16
Ranma
Ranma's Avatar
Originally Posted by akue View Post
Yea the battery has power we tried jumping the car wouldn't work I have a battery tester and it said the battery full soo I have no idea wtf is going on I cant get anything to work
Do you know where the alternater ground wire is so I can look at it? Only wire I have found of ground is the battery ground that goes to the engine itself tried seeing if that was the problem but still no power tomorrow I'm getting the 30 and 40 amp I. The engine bay fuses replaced see if that changes anything
Ok is their power to the battery side of the fuses? Next check the other side then head to the fuse box. Oh yes the alternator ground goes to the battery.
Anyhow check the wires for corrosion. They look good on the outside but may be broken in the middle. First try seeing if the wires have electric. If the battery side of the engine fuse box has power it is not the ground. Check the wire from the battery to the fuse box.
