Old 05-10-2012, 05:22 PM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
you can use the stock acordian pipe if your going to recirculate your bpv. it will work exactly as if you still had a stock setup just with a maf instead of a kvafm
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
