Old 05-08-2012, 02:31 AM   #19
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by fastsupra View Post
...I also took a look and had the shop my car is currently at verify but there is no secondary fuel pump just the fuel injectors and fuel rail. So should I go on ahead and buy a walbaro 255 fuel pump?
Please do not buy a fuel pump. Again, you need a complete fuel system, so please do not peace-meal it together one component at a time. You'll need lots of fittings, electronics, mounting bracket, regulator(?), hoses, etc., etc. I need to know a lot more before we can decide what to do. Could you post some pictures of your engine bay? Also, could you post some pictures of exactly how your current fuel rail is plumbed?
Honestly the easiest thing to do would be to get an entire fuel system from Sound Performance, and then ask them if they can delete the fuel rail and injectors for a reduced price. This still isn't a perfect solution because we don't know exactly what size & thread fittings go into your fuel rail. Even easier would be for you to remove your current fuel rail and injectors, sell them, and then put in the entire Sound Performance fuel system, front-to-back. However, that's probably not the most cost-effective...so let me know your tolerance for work/rework and cost and we'll figure out exactly what to do.
...So then will my AEM Fuel Management not be enough and I will have to either go with the Apexi or full standalone?
Please send me information on the AEM "Fuel Management" unit that you have. A link to the AEM website is fine.
Life begins at 30psi.
