Old 05-04-2012, 02:24 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by fastsupra View Post
When I purchased the car, it already had new injectors installed…
Does it also have a second fuel pump and additional fuel line installed too?
…I guess the reason I wanted that turbo was because of the quick spool valve…
Okay but you can do water lines AND a quick spool valve too…
…I already have the AEM Fuel Management System I didn't realize I didn't have to get a standalone for 650whp…
Then why not sell it? Your best overall driveability will be if you stay with the oem ecu.
… I am currently running a Southbend Stage 3 clutch…
Okay, but what is the width of your rear rims?
…So then if I want to do 650whp, should I go with a 67mm turbo then like in the kit you sent me? …
Yes – any turbo around that size will give you the performance you’re looking for, and you won’t have to max out the boost to get it…which means your meth kit will work fine to suppress the detonation. I’d advise you to talk with the guys at Sound Performance – you can probably get a more ‘cutting edge’ GTX whiz-bang quad ball bearing with 17 unobtanium turbine blades, etc. but you’ll pay a premium for it. The 67mm is a solid, cost-effective way to get the performance+boost level characteristics you’re looking for.
…http://www.spracingonline.com/store/Sound_Performance_Turbo_Kit_67mm_93-98_Supra/28
With that kit I will have to also buy a full fuel system then? …
Probably not, but I need to know more about exactly what is installed in your car right now.
Life begins at 30psi.
