Old 04-30-2012, 11:56 PM   #1
I used redline in the last couple I had apart. The additive is a friction modifier which makes the fluid a little slicker so the clutch packs can slip a little easier when the wheels are turning at different rates. Add just a little, take it for a spin and add more if the diff feels tight or the outer wheel looses traction and chirps through turns. Any COMPETENT clerk at a parts store will be able to help you find it. I don't like buying oils with it already added when just changing fluid in an old diff as there may be too much.
