Old 04-12-2012, 06:15 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by pandrade View Post
hey every one i usualy post in the mk3 section becuase thats what i have but i started a thead about the stock 3 channel abs. cre recomended i post here and more or less ask phil. i was woundering if you could put a 4 channel into the mk3 if the mk4 came whith one. heres where the discusion started
http://www.toyota-supra.info/forums/...ing-valve.html
I posted a response in the original thread. In short, the MKIV TT did come with a 4-channel.
As to whether or not you could put it into an MK3, the answer is very likely yes, but very likely you'd need to run one or more additional/new brake lines.
Life begins at 30psi.
