Old 04-11-2012, 04:05 PM   #2
Constant tension clamps aka CT clamps = The spring type phose clamp you use your fingers or pliers (or special tool) to remove and replace. FAR superior to worm gear clamps or regular T-bolt clamps but just below CT T-bolt clamps.
Crimped hoses have a metal cap that surrounds the entire end of the hose. Not to be confused with AN fittings which are hex shaped (the Supra doesn't have any of these stock anyway, so no worries).
