Old 04-01-2012, 05:23 PM   #10
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by jzzrs180 View Post
...Somehow that still screams twins to me..!...
The stock twins do spool up fast, but only because 1) they're small and 2) because they operate sequentially. Read more about it here:
http://www.mkiv.com/specifications/ncf/ncf93/ncf088.jpg
http://www.mkiv.com/specifications/ncf/ncf93/ncf089.jpg
http://www.mkiv.com/specifications/ncf/ncf93/ncf086.jpg
etc...
...And I heard you can achieve these goals in the 700's still when talking horsepower....
No, the stock twins can't produce 700rwhp. Whomever told you that is 'smoking crack'. If you're talking about aftermarket twins that run in parallel, then sure 800rwhp+ is no problem, but it'll lag just like a big 800rwhp+ single turbo.
...With road racing upgrades where does that get me in top speed, because I do miss 155mph!...
The oem Mkiv Turbo is electronically limited to 155mph. With a US-spec Mkiv Supra Turbo, removing that electronic limitation is as easy as pulling the trac fuse.
...LOL used to have a street bike..ha, and boy did I test that thing...
Bikes are about as aerodynamic as a brick at 150mph+. You'll find an upgraded Supra exceeding that easily because of the much lower drag coefficient.
...Anyway, I read that the oem auto tran can handle up to 500hp and no more, true?...
Depends, but I'd say about 525rwhp reliably. There are upgrades available that will take you to about 675rwhp with the oem TT auto, but to go past that you'll need to swap it out for a TH400 or the like.
...Also I read that all systems are controlled by an integrated engine management system (ems), consisting of a main engine control module (ecm) and several peripheral electronic control units (ecu) for the ancillary systems. How does the obdII play into that system, and if I were to upgrade to a AEM ems, how does that work with the rest of the system, i.e. ecu, ecm?...
An AEM ems works fine with ODBI. With ODBII it's a bit trickier - I've heard of some folks leaving the oem ecu in there for emissions, and using the AEM to control the engine.
...1.can you explain how and where do I get this mixture of higher octane fuel...
Everything you saw in that wikipedia article is accurate.
..., and is it stored in the main fuel cell together?...
Sure. Either that, or you can inject it separately. Your choice.
...What is that ratio?...
Depends how much boost you want to run.
...why is the exhaust gear more important to adjust...
um, because that's what you need to do to increase the peak hp at higher rpms? The information we've accumulated over the years in this community is thanks to dozens of early pioneers that experimented with the Mkiv Supra Turbo in the mid '90s. Lots of things were tried, and only some worked. The ones that worked were published so it's easy for the rest of us to take advantage of. Again, here's the link:
http://www.mkiv.com/techarticles/cam_gear/install/index.html
...Complete upgraded coolant and fuel systems past 500hp,...
No, only the fuel system.
...but with lower horses I'm ok with oem? flex fuel mix (85)?...
No, again it depends on boost. More boost, more octane. Forget hp.
...Say I make a bpu where I maintain about 15psi for now, where does the equate in relation to hp?...
I'd guess about 350rwhp max through a 6spd. Possibly 325rwhp-ish through an auto.
...Pros n cons of single turbo and/or twins?...
Do you mean stock (sequential) twins, or aftermarket parallel twins?
Life begins at 30psi.
