Old 03-29-2012, 03:44 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by John Trip View Post
Can the JDM Imports be modified in the same way as a european supra or is there differences, also does the JDM supra come with TT's and the 2JZ-GTE engine or is it the 2JZ-GE engine ? The reason i'm asking is that the European version of the supra is really hard to come by, where as the JDM supras are really easy to find. What is the biggest differences between the two and which one should i look for ?
Not too sure about european spec, but with a different ecu, injectors, intake cam and oem twin turbos, you could make the japanese-spec Mkiv Supra Turbo perform like the US-spec one.
Life begins at 30psi.
