Old 03-21-2012, 10:14 PM   #3
Oil in the cylinders most likely poured in when the spark plugs were pulled. Otherwise you'd most likely have a chocolate sludge in there as the coolant would have started pouring into the cylinder long before the oil as the oil jackets are further out, smaller and on the other side of the big coolant jackets... I would expect you to already know this.
Look in the FAQ section for a thread on checking diagnostic/error codes and do so when you go look at the vehicles. Unfortunately, if they've rest the ECU or disconnected the battery you won't find any codes indicating detected problems but it's worth checking and only about 5% of sellers think to do this (or are dishonest enough to do it).
Oil in the spark plug galley will cause sluggish performance and oil dumped into the cylinder may foul the spark plugs before the engine has a chance to burn it off. If it's sluggish check the timing, spark plugs, spark plug wires and check for signs of a BHG.
DO NOT BUY A MKIII AS BOTH PROJECT CAR AND DAILY DRIVER!!! A crap MKIII is going to be a garage queen for a long time or it'll cost you a fortune to just keep it running... In which case you can forget about ever being able to afford proper mods and upgrading. These are not a cheap car to restore and upgrading one that's in poor shape is a joke. Honestly, trying to daily drive a MKIII bought on the cheap is usually catastrophic.
