Old 02-17-2012, 11:17 PM   #1
907mge
907mge's Avatar
If you buy the felpro kit it will come with valve seals and the majority of the gaskets needed. That's what did, but got lucky and got the whole kit unopened from someone who didn't use it for 75. There were only a few I had to get from toyota. I would also recommend replacing all the coolant hoses that are easier to get to with the manifolds off. Like cre said there are many other things to do like having the injectors sent out for cleaning and checking your valve shims for proper clearances but if you are not doing it yourself I guess it comes down to how much you want to spend.
