Thread: Touring Supra
Old 01-25-2012, 10:56 PM   #2
Ranma
Ranma's Avatar
Talking
To what are you responding? The float issue? A stiffer suspension will do very little... The goal is to reduce the volume of air moving under the vehicle, remove turbulence and limit the amount of air pushing against and trying to get under the tires. Air dams and a low lip will help more than stiffer suspension, but clearance remains just as much of an issue.
He just seems a bit soft in hard turns. Of course a continuing problem is the car seems to be "flexing" in hard turns and with the top off it becomes a downright problem.
Anyhow, where can I get air dams for under my car? The previous owner destroyed the ones that came with the car.
