Old 01-20-2012, 12:10 AM   #18
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by priyesh12 View Post
Just like you I washed my engine bay,
car ran fine when i started it, no issues but once i left the car running it begins to die. I checked my fuses and everything, and when it came down to the problem, it turned out that the alternator got wet and i ran it without it drying out properly. This burnt out the coils and hence the car would die randomly or loose power. I changed my alternator and everything works fine now. I hope this helps... sorry read that you solved the issue, I'm still sure it had to do with your alternator...
cheers
Congratulations on getting your issue solved. Did you also have to replace your coils?
Life begins at 30psi.
