Old 01-04-2012, 05:12 PM   #1
No, not the chassis ground. Grounds E1 and E2. They're the grounds which connect to the free stud on the lower portion of the intake manifold. There's also a ground on the exhaust side of the head. Make sure they're all clean as possible (sandpaper recommended) and solidly bolted in place... clean the nuts' flange surface too (technically the nuts are single use only but cleaning them works fine).
