Old 12-24-2011, 03:26 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Unknown View Post
Good info, thx and i just thought if I went with 18 inch wheels my car will raise up and avoid as much speed bump scrapes as possible. But I guess Ill just go with 17 inch and hope for the best
18s aren't that bad (only about 6% difference for the suspension geometry to handle). My main point is that you might also consider different springs (ones that don't lower your Supra as much) to solve the speed bump problem. After that, if you still want bigger rims, then get them ...but only because you want bigger rims. Make sense? There are several spring options to choose from - please let me know if you'd like some recommendations.
Life begins at 30psi.
