Old 03-12-2026, 03:31 AM   #19
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Default 5% off Rock Auto orders Expires: 04/10/26
Take 5% off of your Rock Auto order at check out by pasting this code into "How did you hear about us". Expires: 04/10/26 at midnight central time.
332716201295108706
Copy and paste the code in the "How did you hear about us" slot when checking out. Be aware that some sellers on Rock Auto use OEM part photos, but ship other products. Unless it specifically says AISIN or DENSO in the description, don't believe the photos. One example is a LUK clutch master cylinder. The photo says AISIN, but what arrives is made in Taiwan. Rock auto does sell the plunger that can be used to rebuild a early model MK3 clutch master cylinder. Getting the old plunger out can be an ordeal. I had to use a grease gun to push it out. ADVICS brand sells genuine Toyota badged brake master cylinders for early MK3 Supras with and without ABS. Here's a link to the Rock Auto Toyota page.
https://www.rockauto.com/en/catalog/toyota
86.5-90 clutch master cylinder plunger WAGNER MK106004
https://www.rockauto.com/en/moreinfo...t=2000&jsn=616
Water Pump OEM Aisin WPT-025 (Strangely, it does not appear in the 7MGTE list, but works)
https://www.rockauto.com/en/moreinfo...t=2208&jsn=625
Fan Clutch Aisin FCT-060 (says 87-88 turbo, but I don't know why it would not work for all)
https://www.rockauto.com/en/moreinfo...t=6812&jsn=747
Thermostat 190 deg F / 88 deg C, Aisin THT-002
https://www.rockauto.com/en/moreinfo...t=2200&jsn=688
Universal cut to fit 90° bypass Hose for the front and back of the surround pipe on the exhaust side. Dayco / Continental B80400
https://www.rockauto.com/en/moreinfo...choice=0-0-1-1
Universal cut to fit 90° hose for the turbo coolant circuit. Dayco / Continental B87000
https://www.rockauto.com/en/moreinfo...=11564&jsn=771
Turbo car power steering reservoir to pump cut to fit hose from a Honda Odyssey.
Rein part number PSH0409 Once cut, it will flex to reach between. Use your old hose as a template.
https://www.rockauto.com/en/moreinfo...t=7323&jsn=779
Advics / Aisin brake master cylinder with ABS brakes 86.5 to 90, BMT-360 *appears to be out of stock, but may find it elsewhere.
https://www.rockauto.com/en/moreinfo...t=1836&jsn=810
Advics / Aisin brake master cylinder without ABS brakes 86.5 to 90, BMT-106
https://www.rockauto.com/en/moreinfo...t=1836&jsn=806
