Fuel Pump Cuts Out After Startup
I experienced a similar problem where the fuel pump on my 1993.5 Supra would cut off just after starting the engine sometimes. I also noticed that the check engine light would not continuously blink (as it should) when the diagnostic port was wired for the test mode to get the blink codes.
I didn't want to change the wiring to run the fuel system at 12V continuously so I searched for the root cause of the problem. The problem was isolated to to a 10uf 50V 105C electrolytic capacitor on the circuit board of the ECU. In my case the cap was visibly bad as some of the contents leaked out, however also look for electrolytic caps that have swelled up. I didn't get the reference designator for the component, however it is on the stationary circuit board of the two circuit boards in the ECU, and there are few electrolytic caps on the circuit boards.
I was unable to find a schematic for the ECU to determine what function the 10 uf cap performed for the circuit, however after changing it out the fuel pump problem was fixed. I would recommend replacing this cap with the best available electrolytic 10uf cap available and be sure that you have the 105 C temp rating.
