06-12-2015, 05:22 PM
#1
7x6 / H6054 Bixenon Headlight Retrofits
DESCRIPTION: 7x6/H6054 Bixenon Headlight Retrofits
PICTURES: LOOK BELOW (there are plenty)
CONTACT: jayeeyee[at]yahoo[dot]com (preferred)
PAYMENT: PayPal, Cash, Bitcoin
Retrofits are done by per request. Every order is processed as a first come, first serve basis. You can contact me through PM or via e-mail (the latter option would be the quickest) if you have any question regarding your order.
I will be as descriptive as I possibly can about these retrofits to minimize the Q&As. If you should feel the need to ask some specific in which I haven't already covered below, please feel free to contact me. I check my email on a daily basis.
What type of headlight are you using?
1. Nokya H6054/7x6 conversion headlight. The lens are glass and the housing bucket is made of aluminum.
2. Pilot H6054/7x6 conversion headlight. The lens are polycarbonate and the housing bucket is plastic.
3. Both headlights brands are D.O.T/SAE approved.
What type of projectors are you using?
Morimoto MiniD2S 2.0 Bi-Xenon Projectors.
Will I still have the high beam function?
1. Bi-Xenon projectors integrates low/high beam into a single unit. There is a solenoid, when activated, flips down the cut-off shield which lets excess light flood pass the cut-off. Since there are no secondary bulbs, high beams are instantaneous.
2. In order for the high beam to operate on your vehicle, you'll need to splice the high beam output wire (12v+ & ground-) from your factory H4 harness onto the projector's solenoid harness.
3. You can also go online and search for "H4 Bi-Xenon Conversion Harness" to get a conversion harness which is completely plug and play should you feel that splicing, crimping and/or soldering is not your cliche.
4. Alternatively, the "Morimoto MotoControl 9003/H4/HB2" conversion harness works just as well with a bit more cost involved.
Here is a video on Youtube that better explains how the harness operates and how to install it onto your vehicle.
Are bulbs and ballast included as part of the purchase?
Bulbs, ballast and/or wire harness are not included. I can offer advice on which type of bulbs and ballast to choose from since I've tried most of them out on the market.
Please DO NOT, under any circumstances, use poor quality D2S bulbs like the ones you would find on eBay for $10 bucks a set. Those bulbs are so poorly designed that it will hinder the quality of light output. I highly recommend the use of good quality ballast that uses alternating current (AC). HID ballasts that utilizes direct current (DC) are not meant for automotive applications and WILL cause premature failure to the bulbs and ballasts as well as reducing the life expectancy of the entire HID unit.
I'm intrigued about your dislike of poor quality bulbs, please explain...
Projectors have very small tolerances when it comes to bulb alignment. Combine that with poorly manufactured generic eBay-quality bulbs and the precision required, the defect will be magnified through the projector lens. The image below will show what happens when you use poorly manufactured HID bulbs.
Figure A
In this image, the alignment of the arc capsule on the base of the bulb is off by a mere 1-2mm. However, due to this defect, the cut-off is curved downwards. This is caused because the arc capsule is angled upwards on the base. The projector lens "flips" the light output making the cut-off curve downwards. The problem is the same if the cut-off is curved upwards, meaning the arc capsule is angled downwards on the bulb's base. Another obvious way of telling this is the hotspot/focal point of the light output (as circled in red on the image). A correctly aligned bulb should have the hotspot dead centered where the vertical dotted lines are with about 1/2 of the hotspot's lower portion showing.
Figure B
In this image, the alignment of the arc capsule on the base of the bulb is shifted to the right causing the hotspot to shift left beyond the step-up on the cut-off (vertical line). The vertical alignment of this bulb is much better as compared to Figure A since the cut-off is almost straight on the horizontal plain. However, because the hotspot isn't centered on the step-up, everything on the left (if installed on LH side of the vehicle) will be brighter causing the area of the road in the center to be poorly illuminated.
I cannot stress enough the importance of using high quality, properly manufactured D2S bulbs that are built to meet industry standards. I highly recommend using OEM bulbs such as Philips or Osram Xenarcs. If price is an issue, Morimoto XB35 series D2S bulbs are a great alternative option. I've had great success with Morimoto bulbs, they're cheaper compared to OEMs, uses high quality Hallide Salts inside the arc capsule, alignment is spot on, and the light output is second to the OEM output.
(image no longer available)
Do you offer customization for the retrofits?
Customization are available upon request. You may request a different type of shroud if you have a specific style you want as well as halos and/or demon eyes. The buckets and/or shrouds can be painted to a specific color as well. All retrofits will come non-painted with the option of the BMW-styled E46 or Mercedes-styled E55 shrouds by default. Prices will adjust accordingly depending on the amount of customization required, inquire for more info.
How much do I need to modify to make these retrofits work?
The entire retrofit is done for you. You can simply install these headlights as you would for any sealed beam replacement headlights. The only modification (as mentioned above) required is the wiring for the high beam solenoid and post-alignment of the headlight itself inside the headlight assembly and you're good to go.
Additional Info
1. All retrofits goes through a thorough testing process before I ship it out. Every individual headlight goes through a 5-6 hour "burn-in" cycle to release any potential off-gassing that may occur from the combination of sealant used. Every lamp gets submerged into water face down (lens side) for 15 minutes to make sure it is completely sealed and there are no leaks.
2. Please advise - 55w ballast are NOT recommended as there may be a chance where the spike in temperature can cause the reflector bowl to burn. If you must use 50/55w ballast, do so at your own risk and judgement. Burnt bowls will not be covered under the warranty.
3. Retrofit comes with 45 days limited warranty. Warranty covers all craftsmanship defects and starts on date of delivery.
Price: $495.00 (Nokya Set)
FREE USPS Priority Mail (2-Day) Shipping w/ Insurance Included
Retrofits using Nokya housings will cost more due to the extensive labor required when working with aluminum as well as the higher cost for the lamps itself. (Retails $80-$100 per set)
Price: $395.00 (Pilot Set)
Retrofits w/ E-55 Shrouds using Nokya Housings
Retrofits w/ Gatling Gun Shrouds using Nokya Housings w/ Passive Demon Eyes (Red)
Retrofits w/ Gatling Gun Shrouds using Nokya Housings w/ Passive & Active Red Demon Eyes & Hidden Halos
Retrofits w/ E-46 Shrouds using Pilot Housings
Retrofits w/ E-55 Shrouds using Pilot Housings
Tweaked output shot (Results may vary)
