Old 07-02-2005, 04:32 PM   #1
RIsiaah
RIsiaah is on a distinguished road
Hi u all out ther I have a 1988/89 mk3 i have just overhauled the engine following blown head gasket. i have put the hole thing back as best as I could remember also following the manual. Only thing is when i start her up she has low power and bubbleing. I think it is on the vacume side of thing that is causing the problem. Is there any where i may get hold of a diagram of the emmision circuit on the net. if any one knows out there, it would be appreciated. cheers RIsiaah Ps or unless someone may know other reasons for this.
RIsiaah is offline   Reply With Quote
Old 07-05-2005, 03:06 PM   #2
ddmcse
ddmcse's Avatar
there should be a vacuum diagram sticker under side of the hood
http://www.cygnusx1.net/supra/library/TSRM/index.html
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 07-05-2005, 04:03 PM   #3
KingDiamond
KingDiamond is on a distinguished road
What exactly do you mean by bubbling, are you hearing water runnin in the dash?
KingDiamond is offline   Reply With Quote
Old 07-06-2005, 11:33 AM   #4
RIsiaah
ddmcse. I thank you very much that was just the type of thing that i was looking for. I have had alook at your pics of you car you look like youve gone to town on yours and are probably the type of person who may be able to give me advise. but saying that I do not wish to impose to much on one. person. i have also stripped and cleaned everthing. after your healp I got the car running to a good degree. But then after buying a second hand distributor I decided to clean it up. Do you know the correct gap setting for the air gaps in the distibutor.
