-   Supra FAQ (http://www.toyota-supra.info/forums/supra-faq/)
-   -   How to change your oil (http://www.toyota-supra.info/forums/supra-faq/5177-how-to-change-your-oil.html)
SupraSaver87 06-26-2006 05:54 PM
My Rant: Ok, well I just finished changing the oil on my MKIII....don't ask, just don't freakin ask.....I hate Japanese designers...they should have "Big hand" gloves when designing stuff. anyways.....
First: Raise the car up, I used two jack stands just aft of the front tires, on the main support rails under there.
Second: Look for the oil pan, then remove the bolt that is in there.
NOTE: Do remember to loosen it with a ratchet, then put a pail in the way to catch the low velocity stream of oil, then unscrew the bolt the rest of the way with your fingers.
Third(And the hardest): Remove oil filter, and replace with new one.
NOTE: There is a reason I said that the third step is the hardest....SPACE!!! Or lack there of. You WILL NOT have room to get an oil filter wrench in there, so if it is on there pretty good, call you good ol friend bubba over, and let him reef on the thing for a while.
Next, once the oil filter is removed, you now have to lift the filter OVER the brace (You'll know what I mean once you get under there), down over some other stuff, and it will drop down about 6" - 1 foot later.
Well this is still general, but it should help ALOT of ppl.
I opt this get "sticky'd", and if it does, I'll re-write it to sound better, and it'll be more in depth than. It took me about 1 hour to figure all of this out, and I only gave myself 1 hour, and about 8 minutes to do this before I had to be at work....lol.
supra_91 08-01-2006 08:08 PM
the oil filter is easier to take off from the top of the car
Toyotafanatic 08-01-2006 11:27 PM
I use a leather belt for taking out my oil filters, way easier than that tool, on the Supra at least.:)
supra_91 08-02-2006 05:57 PM
the filter tool i use has 3 fingers on it that attaches to a rachet and it really grabs the filter
Bill UK 08-02-2006 09:06 PM
Tried most wrenches over the years, the one I would recommend is No 1 in the photo below, its called a cap wrench, it has a 1/2 inch or 3/8 inch square hole in the end suitable for the standard extension wrench bar,. I got mine in the UK .for about ?3 GBP.
If it helps the Toyota Filter measures 74mm with fourteen flats.
No 2 photo is a K&N filter with built in hex nut shape on the bottom. I haven’t tried them since the cap wrench does the job.
ddmcse 08-03-2006 01:16 AM
this is one reason why they sell oil filter relocator kits
supra_91 08-04-2006 01:24 AM
those K&N oil filters are $12. i buy the fram no slip ones for $5
mrnickleye 08-19-2006 08:13 AM
Few Tips
Best to have engine warm first, makes the oil flow easier. Best to use a new gasket on the drain plug. Make sure the old gasket comes off the pan, and the surface is really clean.
Make sure the old filter gasket comes off the block, and the surface is really clean.
Make sure you put some new oil on the new filter gasket (use your finger to apply).
At home, I drive the car up on the edge of the curb, with the 2 driver's side tires, so I can slip under easy, and the drain hole is on the low side.
supertoyota 04-19-2009 01:39 AM
Quick Oil Drain Valve
Does anybody know about the Quick Oil Drain Valve?
www.qwikvalve.com
I will probably get one for my vehicle. However, if somebody has already installed and give me more info for the item, I would really appreciate it.
Bill UK 04-19-2009 06:24 PM
Not something I would recommend fitting, just imaging going over a speed bump and knocking that tap off. I don’t think the engine would appreciate it.
mikkey9289 05-03-2009 08:07 AM
I Don't understand why you are complaining about the oil filter. I have changed the oil on my 7M's Turbo and NA multiple times, and all I can say is "Beats the hell outta doing it on a 2JZ". I have a spring loaded gap style filter wrench i got from the Matco guy here while i worked at our Toyota dealership. I love it. By far the best filter wrench. I would go as far as saying it was worth the 20 bucks it cost me.
MalumInSe 01-30-2010 04:09 AM
www.qwikvalve.com
Don't waste your time with that crap. You are just asking for something to go wrong. Keep the regular drain plug.
cre 01-30-2010 07:01 PM
There's not much about the design that leaves it open to failure... other than bottoming out just right and ripping it and a chunk of the oil pan out. Myself, I stick with bolts, but I know a few people (including a couple mechanics) running these and not one has had a problem yet.
Green7mgte 01-31-2010 02:02 AM
shoot. you go into it blind once and it takes an hour. 5 minutes every other time. I do remember me cursing the firs time I removed my oil filter. like "wtf? its suposto to come out where!?!?" clank! nope.. Clank, NOPE!
just associate it with learning to tie your shoes.. the rabbit comes outa the hole, makes a loop, runs around a tree.... over some pipes gets oil in his eye, bangs his head... you get the idea.
87mk111 04-14-2010 03:49 AM
i usuaully use the K+N filter so I can use a wrench to get it off.
