Old 12-18-2007, 09:04 AM   #1
XxSupra4LifexX
XxSupra4LifexX's Avatar
XxSupra4LifexX is on a distinguished road
Default My 1986.5 Supra
This is what i started off with. It was a 1986.5 Supra, nonturbo, automatic. I bought it from my g/f's dad for $700.
1986.5 MKIII(7MGE soon to be 7MGTE)
XxSupra4LifexX is offline   Reply With Quote
Old 12-18-2007, 09:33 AM   #2
XxSupra4LifexX
I bought a wreaked 1988 Supra turbo 5 speed for $350. I swapped all of the interior. I took the driver side fender, painted it and put it on my '86.5. I took the complete hatch and wing off the '88 and put it on mine. I painted the side mirrors, the molding, and the grills black. I swapped the manual trans and LSD rear end out of the '88 and stuck it in mine. I also took the rims off the '88(they looked better). Now im just waiting to rebuild the turbo motor and drop it in. Oh yeah, i hit a dip doing about 80mph and one of the buckets on the strut broke and my car hit the ground. When i tried to get it on the tow truck the bottom half of the bumper got ripped off. I have also lowered it, put an intake on it, and and exhaust. and it has a 40,000 mile jdm motor.
ID:	1191   Click image for larger version
ID:	1192   Click image for larger version
ID:	1193   Click image for larger version
Old 12-19-2007, 08:34 AM   #3
Starlight1988
Starlight1988's Avatar
Starlight1988 is on a distinguished road
Supra4life, I wanted to point out that your car should have a place at the rear where the two tow cables should be able to attach and all so i hope this helps you out next time you get it towed and all. Also, I'm looking forward to getting a 7mge auto to 7mgte 5 speed too! I can't wait till that happens!
zoom zoom!
Starlight1988 is offline   Reply With Quote
Old 12-19-2007, 02:44 PM   #4
Chambers
Chambers's Avatar
Hey, nice looking car, suck about your bumper though. It's nice seeing another 86.5, good luck on the engine build!!
"Stuck in the 80's"
Old 12-20-2007, 02:44 AM   #5
XxSupra4LifexX
Yeah, it wasnt hard to change it to manual. all the mounting pieces are there and so is the hole for the master cylinder. everything bolts right up. all you have to do is wire up the nuetral safety switch. you dont even have to change the ecu. it might throw a trans code, what ever you do dont leave the ect switch pluged in. that will send the code off. mine only threw a code a first and then it stopped after about 30 min. if you need anymore help im always happy to help.
Old 12-20-2007, 08:51 PM   #6
Starlight1988
With the transmission and all, do you know if W-58 and R-154 on an MKIII are interchangeable with each other and if there are any differences between the two like the final drive gear or the top speed they will allow?
zoom zoom!
Old 12-21-2007, 02:32 AM   #7
XxSupra4LifexX
the transmissions are interchangeable. the only thing that is different is the brackets that go from the block to the trans. i put the R134 on my non turbo motor. all the bolts line up all you need is the brackets. umm im not really too sure about the differences in the trans. i did 150mph and the rpms werent redlined. i know it will pin the speedo at 160 but im not sure what it will top out at.
Buying a 1986.5 Supra youkilledkennedy Non-Generation Specific Questions 8 03-31-2015 05:02 PM
1986.5 Supra, Just bought this afternoon. MeatRo MKIII Supra 6 09-07-2007 06:38 AM
1986.5 Toyota Supra Nppn Turbo- New Turbo Help ! DarkRaiderz MKIII Supra 6 12-27-2005 09:04 PM
