Go Back   Toyota Supra Forums! Join the Supra forum! > Private Classifieds > Parts Wanted
Old 08-30-2011, 11:09 PM   #1
Tinatyler
Tinatyler is on a distinguished road
Default Need amplifier 86280-14290 ('93-'95 Toyota Supra Amplifier 86280-14290)
Anyone have an amplifier they took out to replace their factory system.
My radio doesn't work, got another head unit, same problem.
my best guess after checking all the fuses is the amplifier is not working.
any guesses or an amplifier would be most appreciated.
tylertina@aol.com
Tinatyler is offline   Reply With Quote
Old 09-12-2011, 09:29 AM   #2
grunge
grunge is on a distinguished road
If you have a good head unit then i would recommended using a Fosgate AMP. I have a Rockford Fosgate amp in my car and it delivers a thumping bass and pretty good power. When buying a amp make sure that you change the speaker wires and the speakers to match with the amp.
For example.....fosgate has a 4 ohm output impedance. So any speaker that you buy should be rated at 4 ohms in. This will give you a good matching with the amp.
Ps: Before conforming that the amp is dead i think you should test it with a phantom load or check the power source with a multimeter.
Hope this helps
Jake Miller
Toyota of Santa Monica
grunge is offline   Reply With Quote
Old 03-07-2012, 12:03 AM   #3
Tinatyler
Smile Looking for Toyota Supra Amplifier 86280-14290
Looking for a used Supra Amplifier that someone has taken out to replace the factory system.
Old 03-07-2012, 02:53 AM   #4
This belongs in the Parts Wanted section. I'll move it there. With a part like this you may have a difficult time. Most vehicles of this vintage have long been fitted with aftermarket components and finding a used, functional amp from a 15-20 year old vehicle isn't likely to be easy.... as you know. I recomment you also post want ads on some of the heavier traffic Supra sites to improve your odds. Including the vehicle year or generation would help too (in this case it was installed '93 through '95).
Tags
radio doesn't work
Have you ever experienced someone SupraHead MKIII Supra 8 10-30-2010 04:06 AM
Toyota Supra Engine Question l_o_t_s_r MKIV Supra 33 08-30-2007 02:29 AM
new motor west_side_supra MKIII Supra 38 04-12-2007 10:11 PM
