Old 10-09-2012, 03:27 AM   #11
http://www.celicasupra.com/forums/sh...olla-6mge-swap
here is my built thread on celicasupra.com
im too lazy to update them both, if any one has a problem with that let me know and i will update this thread.
Old 11-19-2012, 01:32 PM   #12
sneak peak:
engine mounts done.
trans mounted.
drive shaft done.
waiting for gas tank fuel pump, and clutch line...
still doing wiring in my spare time...
Old 11-19-2012, 08:24 PM   #13
ianstaley
ianstaley's Avatar
ianstaley is on a distinguished road
Default 5mg 7MA??
So the other day I was talking to a guy that I had bought some parts off oone of his cars, a 2.5R MK3. he also had a another which he was also stripping and had a 2JZ in there looks very nice, but we got around to the MA61 with 5GE engine 2.8 6 cyl from the celica supra.
Now he came up with the idea that the 5GE is a sort of stroked motor and was very free revving and a better block than the 7Mge block. But he says the MA70 head bolts right up and is a better head than the 5G.
1) is this true that the 5G is a better block and 2) will tha 7M head bolt right on.
Ian
Bored old git that loves his toyota's I have two one a Supra MK3 with a targa top the other is a brit Camry V6.
ianstaley is offline   Reply With Quote
Old 11-20-2012, 02:30 AM   #14
yes 5/6/7m blocks are all interchangeable. performance studs were never made for the 12 valve head though, 7mgte arp studs with ball bearings in the block to keep them up high enough to compensate for the head thickness, or the nuts will never get full thread. is a 5m block better than a 7m block? i would say no, almost the exact same block EXCEPT the connecting rod and crank change from the 2m (2.8L 5mge) to the newer 6m (3L 6m/7m) crank starting some time in 1986 i think? dont quote me on the exact date...
then again in 1989 the 7m blocks received a newer crank the 7m which is also a 3L crank almost the same as the 6m, BUT cylinders 2 and 5 got counter weights for the pistons, resaulting in a max RPM change in 1989+ models.
now, the 2m crank stays the same for 5mge 2.8L models until mid 1984 where all 84to86 5mge 2m cranks got slightly different bearings.
comparing the rods i would say 5m rods are the weakest, the 7mge rods have stronger bolts, and the 7mgte rods are just a little bit stronger than than.
i would also like to point out that a 5mge 2m crank snout is smaller and thinner in diameter than a 7mge 6m crank snout.:
Old 11-20-2012, 02:37 AM   #15
people have put the 2m cranks on 24 heads before, results are better with the 6m crank lets leave it at that...
also the 3L 6mcrank and rods can bolt right into a 5mge block...
i am not convinced the 24 valve head is better than the 12 valve. so far i have found the 24 valve to be more of a hassle, but toyota says the head flows 10-20HP more.
Old 11-20-2012, 12:09 PM   #16
ianstaley
ianstaley's Avatar
What a pair of great reply's so now I know that I keep to the 7M when I need to do some work. I already have ARP bolts and I have a Cometic head gasket. I don't think I will change the engine much, I have and will replace the GE with a GTE uprated oil pump, I have a Fluidyne Ally rad and twin Electric fans to fit, Ally pulley set and some other stuff. Did I say I have owned her from new, delivered to me in Germany in 1987 with 5 kilometres on the clock.
Old 11-20-2012, 01:27 PM   #17
awesome. the 87 mk3 is my favorite. If you went with a multi layer steel hg get the block and head resurfaced. You will be vary satisfied with your arps I think.
Old 01-09-2013, 03:13 PM   #18
i finally purchased the clutch line, and the fuel pump. i went for a walbro in tank.
i still havnt touched the wiring much, i need to buy beer and get some friends over to help.
also goning start fabricating mount to hold a radiator infront of the rad support, i have blocked up the front bumper a little over 2 inches. it should be enough to hide a rad and a fan maby??
Old 01-09-2013, 07:48 PM   #19
as it sits now:
This is going to be a problem...
help on 5mge turbo Guest MKII Supra 7 05-31-2005 07:49 PM
