Old 04-08-2011, 03:34 AM   #1
turbonicsperformance
Default for the 7m fans
http://forum.miata.net/vb/showthread.php?t=412388
its a build thread of my 92 miata that im swapping a 7mgte into
Old 04-16-2011, 02:51 PM   #2
so its a transexual car??
how can you put male parts in a female car???
Old 10-26-2011, 10:07 PM   #3
A 7M-GTE Miata? Tranny? Nah, more of a hipster/metro combo with a gun in its back pocket.
Seriously though, I was curious about your build. The sticker bombing and hood aside I like it a lot (I would have opted for a more conservative/sleeper cam buldge). That is going to be a blast though. How did it affect your weight ratio? I was really surprised at all the clearances, a lot more room in there than I thought and a lot deeper too.
Old 10-27-2011, 06:22 AM   #4
it didnt do much to my weight ratio through it off by about 4%. I wanted to stick with the stock hood but the engine has less than 1/8 inch clearance to EVERYTHING so it can't be lowered any more and with the stock intake the cowl isnt even big enough. but currently it is down for the count ... I bought some bad gas at shell full of a brown dust and it went lean under boost when the fuel pump sock/fuel filter became clogged and my psi dropped
Stock fan clutch Vs Fidanza electric fans bryanf89 MKIII Supra 8 09-10-2010 12:57 AM
Wiring Electric Fans mkiiisupra MKIII Supra 3 03-13-2009 04:58 PM
hydraulic fans oowee623 MKIII Supra 2 09-03-2007 05:22 AM
