Old 10-14-2007, 04:24 AM   #1
BlkSupra84
BlkSupra84 is on a distinguished road
Default negative camber
I was told that my car sits too low and I have a negative camber. That the only way to correct it was to replace my springs. Has anyone out there come across the same problem?
BlkSupra84 is offline   Reply With Quote
Old 10-17-2007, 04:31 AM   #2
Supra2NR
Supra2NR's Avatar
any lowered car will have a negative camber,
thats why with lowered cars the inner thread of tires get eaten more faster
get a camber kit to fix this
Old 10-20-2007, 05:22 PM   #3
suprabahamut
If your ball joints are okay just take it to get an alignment. Usually camber and caster are going to be fixed with adjustment of the asentric bolts near your control arms. so if everything is pretty good like the ball joints then an anignment should not cost that much like around 30 dollors. But ask around like mrnikeleye and some other supra gurus they will tell you the best thing to do.
Old 10-30-2007, 01:34 AM   #4
kwnate
Camber kit??? Its not a honda, just get an alignment.
Nate
Old 10-30-2007, 01:48 AM   #5
Supra2NR
Supra2NR's Avatar
actually not impossible,
a shop owner's father makes his own custom parts for the ma70 chassis
from intake manifolds, mounts, suspension parts, and a camber kit is not so farfetched
i know the guy that owns the shop, last time i was there, his dad was offering me, sum parts for the ma70 chassis
like the tie rods instead of having bushings they will have bearings,
sum sway bars, and other stuff
rear camber problem suprafast MKIII Supra 4 12-29-2004 09:49 PM
