Old 08-31-2007, 02:57 AM   #1
TITAN DOHC V8
TITAN DOHC V8's Avatar
TITAN DOHC V8 is on a distinguished road
Default door control module
hey, i just got my supra running today and i went to put the windows down and they dont go down, and i found a door control module on the pass floor so im not sure where the problem could be. i sure hope its not both window motors but im thinking its that module, im just not sure where it goes. can someone tell me where that module is located, and if that the problem.
thanks in advance
2004 NISSAN TITAN CC LE (born 4/04): BONE STOCK FOR NOW
2003 HYUNDAI TIBURON GT: FEW BOLT ONS
1996 FORD PROBE GT AUTO: NEEDS MAINTENANCE WORK DONE
1994 FORD PROBE GT 5 SPEED: RUNS LIKE A CHAMP
1993 FORD PROBE GT 5 SPEED: WITH A BLOWN ENGINE
1987 TOYOTA SUPRA(NON-TURBO): NEEDS A PAINT JOB AND A TURBO KIT!!!!
TITAN DOHC V8 is offline   Reply With Quote
Old 08-31-2007, 11:05 AM   #2
Cool
if your supra has been sitting for a while it could be as simple as
cleaning the contacts on the switches in the door , they get a little rusty and the windows won't work .
in your case since you found something on the floor indicates someone's been there before
Old 09-01-2007, 05:44 PM   #3
Wink
VERY unlikey that both motors are bad. If the passenger side switch is unplugged, neither side will work.
It is one of the most complicated window control systems I have run across.
Pull the switches and spray clean them with brake cleaner spray or MAF cleaner spray.
This will be a challenging repair. please keep us posted with your progress so I can edit and eventually place the thread in the FAQs section for others to use.
Thanx
Old 09-02-2007, 02:13 AM   #4
TITAN DOHC V8
Thanx
will do, i am busy this weekend so on monday i will start working on it.
but is there a door control module for the windows?? i just found it on the floor and was wondering if that could be the prob, i dont know if there is still one connected or if this one was taken out, or if that module is for something else like power locks or something.
Old 09-02-2007, 03:24 PM   #5
Supra2NR
Supra2NR's Avatar
i jus got my windows working yesterday, the thread in on the mk3 section
Old 09-02-2007, 11:06 PM   #6
TITAN DOHC V8
sweet just checked out your thread, hopefully i can get this figured out quick!
thanks
pics of ignition control module. 77celi MKIII Supra 6 12-11-2007 11:35 PM
performance module supra_91 MKIII Supra 20 10-11-2005 04:23 AM
