Old 07-17-2007, 05:14 PM   #1
kidsusukigsxr
kidsusukigsxr is on a distinguished road
Default Crank Shaft Pully Question
I've been searching and couldnt find anything on this quest.
Can anyone tell me if my pully is bent or needs to be re-seated. First time doing a timing belt and messed up.
My pully and belts are wobbling a little and and makes a little scapping sound while its running. Did i bend the pully or does it need to re-seated?
kidsusukigsxr is offline   Reply With Quote
Old 04-15-2011, 08:45 PM   #2
interested!
Hi!
Your pulley is loose --the crankshaft has probably worn -( this has damaged the woodruff key and slot) - towards a cone shape and the pulley has probably worn to a cone in the opposite direction . this can be repaired by gaining access to the crankshaft with the timing belt and crank gear removed and stepping the crankshaft to PARALLEL to its now smallest diameter up to the gear position using a machined tube with a spigot to maintain a parallel repair --fit/mark/file--fit/mark/file etc ,repairing the slot with a two part metal epoxy paste and fitting a sleeve in a machined pulley with a slot for a new key. finally after all slides nicely together in the correct position,drill a hole through the pulley/sleeve/crankshaft and fit a bolt ( head and thread removed )to prevent rotation on the crank --removing strain on the woodruff key.it worked for me 10 years ago and came apart easily 8 years later for a new timing belt. fit a new crank seal and a new timing belt etc for a long life.
Prop/Drive Shaft, brake question spudz29212MKIII MKIII Supra 13 05-31-2008 07:15 PM
question on removing crank shaft kidsusukigsxr Non-Generation Specific Questions 12 07-07-2007 03:49 PM
Need help with front crank shaft pully bolt tmetal_blk Non-Generation Specific Questions 3 06-24-2007 06:24 PM
crank shaft pulley puller supramacist MKIII Supra 30 04-18-2007 02:27 AM
Crank shaft pulley.. MA70_858 Non-Generation Specific Questions 3 07-28-2006 04:47 PM
