Old 06-07-2007, 04:58 PM   #1
jpham8
jpham8 is on a distinguished road
Default Nitrogen In Tires...good Or Bad?
The last time I went to have my tires re-placed, they talked me into having my tires filled with nitrogen is this good or bad...they essentially told me that the life of the tire will last longer. Is this true?
jpham8 is offline   Reply With Quote
Old 06-07-2007, 09:52 PM   #2
dcrusupra
dcrusupra's Avatar
I had it in my tires. I didn't notice a difference. Air is 70% nitrogen anyway. It does however keep the tires cooler. I got it for free so it was worth a try.
New Rebuild
My CarDomain
Old 06-08-2007, 03:16 AM   #3
dgl94456
dgl94456 is on a distinguished road
Default nitrogen in tires
nitrogen in tires is GOOD because nitrogen is an inert gas and therefore will not react in any way with tire material. And, because it is inert, it does not expand and contract with temperature or atmospheric pressure changes, which is why aircraft tires are inflated with nitrogen vice air.Air is 79% oxygen which is a VERY active/reactive gas.
dgl94456 is offline   Reply With Quote
Old 06-08-2007, 03:46 AM   #4
Red face Oops
Originally Posted by dgl94456
nitrogen in tires is GOOD because nitrogen is an inert gas and therefore will not react in any way with tire material. And, because it is inert, it does not expand and contract with temperature or atmospheric pressure changes, which is why aircraft tires are inflated with nitrogen vice air. Air is 79% oxygen which is a VERY active/reactive gas.
Sorry Mate, but definately not true. In TRUTH, it approx 21% oxygen in the atmosphere. 78% nitrogen.
http://en.wikibooks.org/wiki/Meteoro...the_Atmosphere
And Remember...GOOGLE IS YOUR FRIEND.
BUT...you are correct about nitrogen in tires.
http://ezinearticles.com/?Selling-Ni...-Air?&id=38142
Old 06-11-2007, 06:56 AM   #5
4ageBT
4ageBT's Avatar
4ageBT is on a distinguished road
Nitrogen is good for the tires. It makes your tire pressure constant no matter the road temparature. It keeps your tires in good shape because of the prevention of too much pressure.
Autoparwarehouse blog..
4ageBT is offline   Reply With Quote
Old 08-13-2007, 01:55 PM   #6
finaltable
finaltable is on a distinguished road
Nope. All gases, regardless of molecular composition, behave according to pv=nrt (pressure*volume=number of moles * constant * temperature.) It is IMPOSSIBLE to have constant pressure under rising temperature without changing one of the other factors at the same time. Since the inside of a tire is a roughly constant volume, unless you are planning on leaking gas when the temp goes up the pressure WILL increase.
Current ride: Not a Supra :-(
finaltable is offline   Reply With Quote
Old 08-13-2007, 02:32 PM   #7
Talking Facts are out there
Googling around brought these sites up. Check them out.
http://www.parker.com/ead/cm2.asp?cmid=9087
http://www.parker.com/ead/cm2.asp?cmid=9093&
The tires run cooler with pure nitrogen. While an air filled tire's pressure will increase 5*-10* when hot, a nitrogen filled tire will increase 1*-5*.
http://www.parker.com/balston/English/coolrunning.pdf
[quote]
"Sheehy and his technicians service their trucks as they come in off the road, and they’ve been checking tire pressures consistently as part of their nitrogen test. According to Sheehy, every truck leaves home base with their drive tires inflated to 85 pounds. “If you check the tire pressures right off the road, a normally aired up tire will come in at between 90-95 pounds consistently when they’re hot. The nitrogen comes in between 85 and 90 pounds. It’s more stable, which means they’re running cooler".
But for me...since 80% of my driving is short trips around town, I use regular air, and I tend to wear the tread out quicker than the rest of the tire...and I do check and top up my air pressure (36psi) regularly.
Old 08-13-2007, 04:18 PM   #8
fulljapan
fulljapan is on a distinguished road
Once again mrnickleye cuts it.
fulljapan is offline   Reply With Quote
Old 09-01-2007, 01:00 PM   #9
Shaihulud
Shaihulud is on a distinguished road
It's mostly a way for tire stores to make an extra 5.00 per tire.
Shaihulud is offline   Reply With Quote
Old 06-04-2008, 07:53 AM   #10
ultimatewarrior8888
ultimatewarrior8888 is on a distinguished road
Post Good writing
Good writing. Keep up the good work.I love this site, let's try our best together, seize everyday, just do it!Runescapemoney.
RunescapeCoin
ultimatewarrior8888 is offline   Reply With Quote
Has anyone purchased tires from these sites? Chambers MKIII Supra 7 08-16-2007 03:27 AM
