Old 04-15-2007, 05:30 PM   #1
wingshooter92
wingshooter92 is on a distinguished road
Question sprak pluge question
hi i just gopt done changing my sparkplugs out of my 88 N/A supra and 4 otu nof the 6 plugs were coted in oil and i cahnged them but i took the four boack out and they were coted in oil and help please
wingshooter92 is offline   Reply With Quote
Old 04-15-2007, 07:58 PM   #2
Supra2NR
Supra2NR's Avatar
Ur valve cover seal could be bad
Old 04-15-2007, 10:17 PM   #3
wingshooter92
Default ok wat next
all four of them and will this cause a miss in the engine
Old 04-16-2007, 03:58 AM   #4
j3pz
is it oil on the top side, or in the engine?
edit: sorry dumb question...
Old 04-16-2007, 04:46 AM   #5
I believe you are saying that your plugs were coated with oil...wet oil !?
Yes? Then the hole the plug sits down in is full of oil. This gets in from leaking valve cover gaskets.
Chamge them. and the center one over the plugs, and that will fix the problem.
Read the Got oil on top of your spark plugs?? thread in the
MKIII (1986.5-1992) section.
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
