Old 02-07-2007, 09:58 PM   #1
phillip_o_hj
phillip_o_hj is on a distinguished road
Default Transmission Fluid Change
I'm new to the Supra game, and I need help. My transmission sounds like it is low on oil, and it shifts kinda hard. Do I have to drop the tranny to find a fill plug, or do I drain it all out and pump it in from the bottom? Thanks for the advice
phillip_o_hj is offline   Reply With Quote
Old 02-07-2007, 10:38 PM   #2
phillip_o_hj
BTW, its a MK3 non turbo, 5spd. bone stock
Old 02-07-2007, 10:53 PM   #3
the driver
the driver is on a distinguished road
Question oil change
Is it auto or manual? I could give you tons of info on both!
the driver is offline   Reply With Quote
Old 02-07-2007, 11:09 PM   #4
the driver
Talking
5spd there is a drain and a fill plug both are the exact same size so it shouldn't be hard to find the fill plug I would you a synthetic gl5 80-90 also check the mount on the rear of the trans grab the tail shaft and push up if you can push and the trans move the mount has separated a real common prob can affect shift they are cheap and easy to replace also when I removed mine to put in a stage two clutch I removed the shifter also easy to remove the grease was so old and dried I picked up in one piece it was so old it was like a rock I used trans assembly lube and pack the shifter housing with it now it shifts smooth as butter toyota 5spd are practically bullet proof at least in my expirance mine has 250000 miles on it I also have two spares and I drive mine like its stolen
Old 02-09-2007, 05:24 PM   #5
scruffboy
scruffboy's Avatar
Default Trans Mount?
Where exactly is the transmission mount? Do they show it in the TSRM? If you could be a little more specific I'd like to visually inspect it.
Thanks,
Scruffboy
Old 02-09-2007, 05:59 PM   #6
the driver
Default trans mount
if you look under your car at the rear of the trans there is a cross member that the trans rest on you cant miss it well anyway in between the cross member and the trans there is a rubber mount just looking at it really isnt enough unless it cracked of obliviously rotted out if you strong you can push up on the rear of the trans to see if it is separated if your not strong use a pry bar or crowbar anything you can fit between the cross member on trans and pry up if its good you wont be able to move it more than a half inch if you can pry up more than that and the mount isnt good and I would replace asap also i would have the u joints inspected as well
Old 02-09-2007, 08:39 PM   #7
scruffboy
scruffboy's Avatar
Default Thank You
simple answer to simple question
Old 02-09-2007, 08:56 PM   #8
the driver
Default no prob
let me know what you find out
Transmission fluid check cgreiner MKIII Supra 1 09-22-2008 02:09 AM
Transmission Fluid capacity suprabahamut Non-Generation Specific Questions 2 09-18-2008 04:30 AM
Transmission Fluid Change shiftysupra MKIII Supra 2 09-16-2008 11:21 AM
transmission fluid suprabahamut MKIII Supra 2 08-12-2007 06:04 PM
Draining Transmission Fluid? RNEMESiS42 MKIII Supra 20 05-17-2007 10:17 AM
