Old 08-24-2006, 01:18 AM   #1
tone loc
tone loc's Avatar
Default bleeding brakes
i was just wondering how to bleed my brakes. like do i have to take the wheels off and stuff. and if you have any tips to keep it less of a mess. thanks
Old 08-25-2006, 02:01 AM   #2
Supra2NR
Supra2NR's Avatar
i think you do have to take your wheels off
they sell bleeding kits at your regular auto parts store
that can help you a lot
Old 08-25-2006, 06:59 PM   #3
supra90turbo
supra90turbo's Avatar
flare wrenches, vacuum line, and an empty soda bottle.
Yes, you have to remove your wheels.
loosen the bleeder, put the vac hose over the end of it and into the bottle.
You can do all 4 like this and let it gravity bleed if you'd like... works just as good, it's just less work. It does take a while though, so only do it this way if you've got lots of time.
Otherwise, start from the furthest point from the master cyl. in order, RHRR, LHRR, RHFRT, LHFRT. Fill master occasionally so you don't run low and push air into the lines, because that just means you've got to do it all over.
You NEED a helper if you're gonna do it this way.
Gravity bleeding you can do yourself.
Two Issues: Front Brakes and Sporadic Vibration Chambers MKIII Supra 0 11-03-2007 04:15 PM
Brake Bleeding Woes... Lunch2000 MKIII Supra 4 09-11-2007 02:18 PM
Bleeding brakes? Torkster MKIII Supra 3 07-13-2007 03:48 AM
Having a lot of difficult bleeding the brakes Chambers MKIII Supra 4 05-24-2007 11:38 PM
Brakes 5M Vs. 7MGTE panda-supra MKII Supra 3 03-22-2006 09:07 AM
