Old 07-29-2006, 09:22 AM   #1
1JZ_locost7
1JZ_locost7 is on a distinguished road
Default How much hp can a w58 handle???
Hi, how much reliable hp can a toyota w58 box handle? I am currently installing a 1jz into a lotus 7 replica so weight will be under 700kgs max. Many thanks.
1JZ_locost7 is offline   Reply With Quote
Old 07-30-2006, 06:07 AM   #2
tone loc
tone loc's Avatar
on the supra 7mge the w58 can handle 300-350 hp.
Old 07-30-2006, 07:15 AM   #3
supra90turbo
supra90turbo's Avatar
supra90turbo is on a distinguished road
Your best bet is to put an R154 behind it. It'll handle all the abuse you can throw at it, and as the 1JZ was never originally mated to any W-series trans, you will have to make a custom bellhousing adapter to bolt it up.
1JZ R154 is the way to go. Just make sure you get a trans from a 1JZ car, otherwise you'll be buying a 1JZ bellhousing, and they go for about $350 last I checked.
supra90turbo is offline   Reply With Quote
Old 07-30-2006, 09:23 AM   #4
1JZ_locost7
Thanks guys, have found a small engineering company who can make an adapter plate to fit the w58, have looked around but the r154 is practicaly non existent here in south africa.....
My Tricky Door Handle DarkRaiderz MKIII Supra 10 11-21-2005 03:41 PM
Door handle teko_SuPrA Non-Generation Specific Questions 0 11-02-2005 10:37 PM
