Old 07-16-2006, 08:29 PM   #1
GoddardJock
GoddardJock is on a distinguished road
Smile 2jz-gte SWAP HELP!
OK. I need to know how possible it is to put a 2jz-gte into a mk III model supra. Any response is appreciated. If it is not exactly a good idea, i would like to know why. Thanks
GoddardJock is offline   Reply With Quote
Old 07-18-2006, 12:54 AM   #2
Supra2NR
Supra2NR's Avatar
there's been a lot of threads about this swap, and yes it has been done b4
few things that i can tell you,
u need to bang the firewall for the second turbo to fit
wiring harneses
and a tranny for the 2jz
other stuff you can jus ask around in here
Old 07-19-2006, 11:29 PM   #3
GoddardJock
Default hmm
Are the engine mounts the same? Or will there be other custom work that may be too expensive to consider?
Old 07-23-2006, 05:32 AM   #4
Supra2NR
Supra2NR's Avatar
if your willing to go the 2jz conversion i think the mounts should be the least of you r worries, its jus one of those things that you need to go all out or dont go out at all
Year to Year MGE Swap changes Mr.Bojangles MKIII Supra 6 01-10-2008 07:44 PM
1JZGTE swap question supradaddy0803 MKIII Supra 1 04-12-2007 04:56 PM
to swap or not to swap edelmar417 MKII Supra 16 04-10-2007 12:06 AM
89 NA => Turbo SWAP INFO akadiablo MKIII Supra 0 12-09-2005 06:21 AM
MKIV auto to manual swap?? awd4g63tsi MKIV Supra 0 10-24-2005 08:46 PM
