Old 03-31-2005, 10:29 PM   #1
snafu54
snafu54 is on a distinguished road
i have a problem im not getting any spark. could the wireing harness be diffrent from 86 to 87?
snafu54 is offline   Reply With Quote
Old 03-31-2005, 10:48 PM   #2
monkihead
SP58GT
monkihead's Avatar
no, both motors should use the same firing order. did you check your ignitor? is the signal from the distributor reaching the ignitor or coil?
monique- better off dead
Old 03-31-2005, 11:48 PM   #3
snafu54
i changed the distributor i dont know about the signal how do i check it?
Old 04-01-2005, 03:43 PM   #4
monkihead
SP58GT
monkihead's Avatar
i'd have to check my book on it, but this web site might be able to help. its designed for the 87-92 but they didnt change a whole bunch between the ignition systems.
http://www.cygnusx1.net/supra/library/TSRM/index.html
