Old 06-15-2006, 12:38 PM   #1
scruffboy
scruffboy's Avatar
Default on side of road, help fast
I was on my way to work when I noticed my dashlights coming on. I pulled over (on a hill) and turned off car. Wouldn't restart. Checked battery cables, tight. Jump started car and it was running, but at like 2500 rpms idle. Tried to drive home but died. Got a jump and restarted, but when I went to pull away, it sputtered and died. Not sure, sounds like fuel mix maybe. Checked AFM, was on tight. Any suggestions. I need help fast as my car is on a side street in Newark, New Jersey and won't last too long.
Thanks
Scruff
Old 06-15-2006, 12:50 PM   #2
dcrusupra
dcrusupra's Avatar
I'm thinking a bad alternator.
New Rebuild
My CarDomain
Old 06-15-2006, 02:11 PM   #3
theWeezL
theWeezL's Avatar
I concur, its likely that your alternator failed and used the battery to drive on till it was dead. If you dont have far to go, you could borrow a fully charged battery and limp it home to repair the alternator. wont get real far but maybe far enough.
____________
Old 06-15-2006, 02:42 PM   #4
Supra2NR
Supra2NR's Avatar
were you going uphill or downhill when this happend?
Old 06-15-2006, 04:03 PM   #5
scruffboy
scruffboy's Avatar
Default Thanks
Yeah, I'm kinda leaning to bad alternator. The battery is new, so its not that. I don't have a spare battery, but if I charge it long enough, will I be able to get about 3 miles to home? The first indication of something was wrong was my my radio stopped. Then I noticed dash lights come on. But after I jumped it, shouldn't I have been able to get home?
Scruff
Old 06-15-2006, 04:49 PM   #6
theWeezL
theWeezL's Avatar
Scruff
no becuase the instant you start your vehicle you are drawing on that battery reserve. what you could do is to hook up the jumper cables and let the donor car charge your battery for a little while, then start it and drive immediately to your destination, hoping you have enough juice to get there...save all electrical power you can by keeping the radio, a/c, lights, etc off, conserve power.
"with all due respect sir, I think this will be our finest hour..." - Gene Crantz, Apollo 13
____________
Old 06-16-2006, 01:36 AM   #7
j3pz
when i read this, the alt is exactly what i was thinkin. when you start your car, the starter motor has to use alot of power to turn over the motor. i believe a fresh, fully charged battery will get you home.
Oxity Bank Note Road Rally Oxity-X Road Racing & Autocross 1 05-22-2006 12:54 PM
Passenger side window kewlcoconut MKIII Supra 1 03-29-2006 07:58 AM
Car on the road!!!! bigal0043 MKIII Supra 12 09-22-2005 01:46 PM
